Closed Solved
650W Power Supply
Looking to get a 650w (if that's enough) power supply for my i5-3570k OC'd and HD 7870 with the possibility of adding another 7870 in the future.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194103
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
Any suggestions or ideas are greatly appreciated
4 answers Last reply Best Answer
More about 650w power supply
  1. Best answer
    Yes 650W is more than enough for a build with 7870 CF.
    Out of the three PSUs listed (Corsair TX650 V2, Lepa B650-SA and XFX Core Edition PRO650W (P1-650S-NLB9)) the XFX is the only one which has the correct number of PCIe connectors (four) for two 7870s, as a single 7870 needs two PCIe connectors each.
    So I would recommend you get that one.
    However the 750W version is cheaper at NCIX US:
    XFX ProSeries 750W Core Edition ($85)
    http://pcpartpicker.com/part/xfx-power-supply-p1750snlb9
    And the 650W version has a $10 rebate at NCIX US as well.
    This is also at a good price and a much better unit IMO:
    Rosewill Capstone-750M ($110 @ Newegg / 20% off promo code)
    http://pcpartpicker.com/part/rosewill-power-supply-capstone750m
  2. Best answer selected by rholdy123.
  3. This topic has been closed by Mousemonkey
Power Supplies Intel i5 HD Components Product
