Hey guys, I'm not sure if this is the right forum to post this question but here it is anyways..
Below shows my build a few days ago before I made some alterations, and now my comp doesn't start up.
My build as of a few days ago:
MOBO: ASUS P8Z68 DELUXE/GEN3 LGA 1155
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155
Ram: G.SKILL Ripjaws Series 16GB
GPUASUS AMD Radeon HD 7970
PSU: XFX Core Edition PRO650W
What I changed was the CPU, the CPU cooler, and the amount of ram.
New CPU: i7-3770K Ivy Bridge 3.5GHz
Same Ram but less memory: G.SKILL Ripjaws Series 8GB
CPU Cooler: Corsair H100
After changing my setup my mobo says: 2E, and there is a red led light that says dram led.
Basically its saying this is a memory problem? Everything worked right before these changes, and I have tried 1 stick of ram and rotating to the other stick of ram and 2 sticks of ram at once(and they are in the right slots). Could the ram be dead even though the system ran w/ 16gb? Is there some compatibility issue? I also tried reseating the cpu.. twice.. and i have removed the mobo battery for hard restart, and pushed that memok button. Anyone have any tips?
Thanks so much in advance!!
