New System Build
Hey guys,
I have not put a box together in a long time. I'd like to get some input on what I am looking at and let me know if I am missing something or better components recommendation. Or if you think something is overkill etc
budget 1500 +/-
Goal: mid-range gaming system, will run everything well and that will last a while.
Required parts: i5 2500k, 7970 GPU
COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x ...
Item #: N82E16811119160
Return Policy: Standard Return Policy
-$10.00 Instant
$20.00 Mail-in Rebate
$159.99
$149.99
SAPPHIRE Radeon HD 7970 OC 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card (11197-01-40G)
Item #: N82E16814102982
Return Policy: VGA Standard Return Policy
Protect Your Investment (expand for options)
$479.99
AMD Gift - AMD Gaming Evolved Three For Free Coupon
Item #: N82E16800995122
-$99.99 Saving
$99.99
$0.00
CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC ...
Item #: N82E16817139011
-$15.00 Instant
$20.00 Mail-in Rebate Card
$189.99
$174.99
CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M2A1600C10
Item #: N82E16820233246
Return Policy: Memory Standard Return Policy
$119.99
CORSAIR Flash Voyager 8GB USB 2.0 Flash Drive Model CMFUSB2.0-8GB
Item #: N82E16820233037
-$8.99 Saving
$8.99
$0.00
ASUS P8Z77-V DELUXE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131818
-$10.00 Instant
$284.99
$274.99
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
Item #: N82E16819115072
Return Policy: CPU Replacement Only Return Policy
$219.99
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Item #: N82E16820148442
5 answers Last reply
More about system build
  1. What's the primary use for this build? If it's gaming then 2 x 8GB is major overkill, and you definitely want to go Ivy if you possibly can for PCI Gen 3. It's a good start for sure.
    Here's what I would suggest for $1500:
    Case: Corsair Carbide 500R - $139.99
    PSU: PC Power & Cooling Silencer MKII 950W - $149.99
    Motherboard: Asrock Z77 Extreme 4 - $139.99
    CPU: 3.4Ghz Intel Core i5-3570K - $249.99
    Cooler: Cooler Master Hyper 212 Evo - $34.99
    RAM: 8GB G.Skill Ripjaw X 1600MHz 1.5V - $46.99
    SSD: 128GB Crucial M4 - $124.99
    HD: 1TB Samsung Spinpoint F3 - $109.99
    Optical: LG Blu Ray Burner - $79.99
    Video Card: Sapphire Radeon HD 7950 - $399.99
    OS: Windows 7 Home Premium - $99.99
    Total: $1,576.89
    A little bit over budget but if you don't need Windows 7 you can swap that for a 7970 or 680 and come in a little under budget.
  2. Yea, this will strictly be gaming only.
    Love the suggestion btw
    I just realized that build is now almost exactly the same as my own build. :lol:
  5. I see you have upgraded your CPU, g-unit. How do you like it? I'm looking at buying one.
New Build Systems Product
