Hello,
I noticed one of the fans in my Norco case wasn't spinning. I removed the fan and noticed that one of the pins on the fan mount was bent - so I stupidly took insulated tweezers and tried to correct the pin placement. There was a small spark and the computer restart immediately, I heard the power supply switch off and on and the motherboard light cycled. I pulled one of the hard drives immediately and out of the 24 it worked fine. Everything works perfectly right now, but did I damage anything? The fan was connected via 2pin molex and a SATA - molex adapter via a Corsair HX70 power supply.
Thanks.
Thanks.
