Extreme Liquid Cooled System
EVGA X79 Classified Motherboard
Intel Core i7 3960x
EVGA GTX 680 Hydro Copper GPU x4
Corsair Dominator RAM 32GB
Samsung 830 Series SSD 512GB
Western Digital Velociraptor 1TB x3
XSPC Raystorm Copper CPU Waterblock
XSPC Single 5.25" Bay Reservoir
XSPC X20 200 Single Bay Reservoir Pump
Phyobya G-Changer 480mm Radiator
XSPC HighFlex Hose Red/UV Orange Tubing
Thermaltake PC Coolant
Silverstone Strider 1500 Watt Power Supply
Asus BW-B1LT BLu Ray Drive
Corsair 800D
Dell Ultrasharp U2711 x8
Razer Blackwidow Ultimate
Cyborg R.A.T 9
Razer Scarab
Bowers and Wilkins MM-1
4 answers Last reply
More about extreme liquid cooled system
  1. Darn... i was looking at the wrong motherboard on EVGA's website. I will edit that. And i will change that PSU supply too.
  2. I don't have a set budget. I just want what's best of the best. i am just going to skip the soundcard based on your recommendation.
  3. I'm all with you on an overkill system... But, even if the budget is infinite, I'd go for two 680's for now (again, if you can find them) tops, surely you wouldn't notice any gain from four over that for months (or possibly years, lol).
    You should look at more radiator space too, especially if you're looking at multiple GPU's. I've got two 240mm rads in my case now, and am still above temps I'd like to be at. At least another 240 would be smart for four cards if your set on that.
    edit: 4 won't fit in the 800d either- only 7 slots on back
  4. if the x79 is a waste what woul u recommend
New Build Systems
