Help on new build based on i5-2500K & Radeon 7850
So my budget for this build after tax is about $750 CAN (about $664 before tax) after rebates and I think I have a fairly good choice of parts, but as this is my first build I'm still a little unsure in some areas. Also I already have an hard and optical drive, and all other peripherals so those aren't needed. This is planned to be built within 2-3 weeks.
CPU: Intel Core i5-2500K - 229.99
GPU: AMD Radeon HD 7850 - 249.99
RAM: Corsair XMS3 4GB - 19.99
CPU Cooler: Arctic Cooling Freezer 13 - 25.99
Case: Thermaltake V3 Black - 29.99
These parts I'm fairly certain about, I don't think I can get anymore performance for the price at the moment (if I'm wrong please correct me). For the GPU I was considering the GTX 560 TI, but for the extra, I think the 7850 is a better choice. Also GTX 480 looks promising for the price, but I'm a little hesitant buying a GPU from two series ago. That brings the total to $555.95, so that means I've got $108.05 to play around with for the PSU and motherboard. I know that seems kind of tight for the parts but that's all my budget really permits.
PSU: Thermaltake TR2 600W - 45.99
Motherboard:
MSI H64AM-P23 B3 Intel H61 - 59.99
Asus P8H61-M LX PLUS (Rev. 3.0) - 64.99
Gigabyte GA-H61M-S2PV mATX - 64.99
I think a 600W power supply should be fine to power these parts, my only concern is that down the line if I decide to add a second 7850 in crossfire; would the 600W power be sufficient or should I bump up to 750W? From what I know (which isn't much) with overclocking the motherboard can be just as important as the processor itself. I plan to do some overclocking, nothing extreme, so I think these boards will suffice.
The main reason for this thread is regarding the PSU and mobo, and just general feedback for the build/things I may have overlooked. I just want to make sure I'm prepared before jumping into things.
SIDE:
If it wasn't obvious this rig is meant for gaming primarily (sc2, diablo 3 - soon my pretty, bf3, you get it) and light image/video editing.
EDIT:
This hec Zephyr MX 750 PSU looking really good for 69.99
4 answers Last reply
More about help build based 2500k radeon 7850
  1. Cheeseman, these specs look good. The only thing is if you are purchasing a H61 based motherboard you will not be able to overclock your 2500k. This chipset does not allow independent changing of the CPU multiplier. If that is the case then I would suggest skimming down to an i5 2400 OR upgrading the motherboard to either a p67 (if you can find one) or a cheaper z68 motherboard such as http://canadacomputers.com/product_info.php?cPath=26_722&item_id=041921
    or
    http://canadacomputers.com/product_info.php?cPath=26_722&item_id=038863
    or
    thanks.
    are p67 and z68 based motherboard the only one compatible with the 2500K for overclocking, or just the cheapest options?
  3. stevecheeseman said:
    thanks.
    the p67 has the ability to only overclock cpus, z68 does both. h61/h67 are budget boards which are not supposed to do either. other than that, all 3rd generation boards (b75,h77,z75, z77) have the ability to overclock(though you shouldnt on a h77 board)
  4. look at this if you don't mind 2 dimm slots only
    Motherboard: 84.99$
    ASRock Z68M/USB3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
    (USB 3.0, XFast LAN / USB, Magix Multimedia Suite)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157270
    was doing a cheap build and came up with that >.<
New Build Systems Product
