Amd 6990 problems
  • Radeon
  • BIOS
  • AMD
  • Graphics
February 29, 2012 4:01:12 AM
i bought a gigabyte amd 6990 and it preforms worse than my gts 250 that i had a couple years back, it artifacts like crazy when im on the desktop, games that arent hardware demanding like l4d or cod4 have 10-20fps, when i uninstalled the bios and install a new one the screen just goes black for ever(let it run for 24+hours and it was still black) none of the bios make a difference except the one on that came on the cd(it gives me the best windows score lol) i have RMA three times, first time they just sent me back my old @#%$ing card (i know it was mine i wrote **** on the bios label) the other two cards they sent me still perform the same, i have flashed the bios on my mother board and that did not help, i bought a new asus crosshair iv extreme and several different ram kits from g.skill, corsair, mushkin, ocz, and even amds own branded ram, but nothing works and i tried a amd 955, 970, 1090t, and 1100t and that does diddly. the only time my 6990 performs well is when i have it overclocked to 930mhz and 1350mhz on the memory and i have the fan turned to 50% so it can cook at 60c, when i turn it to full the temp drops to 46c and it starts with the horrible horrible problems.
i have tried it with windows 7 64bit(and 32bit) ultimate, home, professional, vista 64bit(and 32 bit) ultimate and home and good old windows xp
current setup:
OS-windows 7 64bit ultimate
RAM - G.Skill flare 8gb
Mobo - Asus crosshair iv extreme
ssd - OCZ agility 3 480gb
PSU - corsair 1200w
CPU - phenon II 1100t @ 4.2ghz on liquid
GPU - AMD Radeon 6990 <------- I'm betting that is my problem
More about : amd 6990 problems
February 29, 2012 4:09:07 PM
Why are you toying with the BIOS if you've never had it running stable in the first place?
m
l
March 4, 2012 1:25:53 AM
it seems to be the only way this card will run with out to many problems although it does not fix slowness in games like l4d and cod4 and skyrim. but i think i have found a more permanent solution, bought intel i7 2700k and asus maximus iv extreme with two gtx 580's. so far with this set up my amd hardware has not been acting up.
m
l
