Yo. I'm in the process of building my first computer. This is what I have so far.
Case NZXT Phantom Enthusiast ATX Full Tower Computer Case
Motherboard ASRock Z77 Extreme4 - M LGA 1155
CPU Core i3 i3-2130(Q0 Sandy Bridge 3.4GHz
RAM 4 x 4gb DDR3 1600 Kingston
Power Supply Ultra LSP750 750-Watt
Cooling Kit Thermaltake CLW0211 BigWater 760 Plus Liquid Cooling Kit
HDD 2 X Western Digital 250GB 7200RPM SATA 6.0Gbps 3.5
Graphic Card MSI Video Ge Force GTX430 1024MB DDR3 PCI-e/Express Video Card
OS Windows 7 HP
I am wondering if there is anything I can do to reduce cost with no loss to performance? Also is there anything I am missing? I chose the i3-2130 for now, because this Motherboard can accept the i7. So I figured I would be ok with the i3 and eventually upgrade to the i7. Also, I was wondering if there might be a Motherboard with the exact same specs as this one, but with 3 PCI slots instead of 2. A brief search led me to the AsRock H77 Pro4/MVP. However, there is a cost difference, with the AsRock Z77 being higher, so that compels me to believe that it is better?
Any help would be greatly appreciated! Thanks
OS Windows 7 HP
