$600 System Build
G
Guest
Guest
Approximate Purchase Date: (e.g.: this week (the closer the better))
Budget Range: (e.g.: 600-800) Before / After Rebates
System Usage from Most to Least Important: Web Browsing, Minecraft + Flash Games etc. and Homework
Parts Not Required: Monitor and OS
Preferred Website(s) for Parts: newegg.com (but cheaper is better)
Country: U.S.
Parts Preferences: none
Overclocking: Yes (as far as I can go without damaging the life)
SLI or Crossfire: Not now
Monitor Resolution: (not sure)
Additional Comments: Keep it in budget I have no preference for anything (if you want a total revamp that's fine)
I'm deciding to sell my tablet now so I should be able to get a PC around $500. I'm open to totally changing everything in this build. So comments and suggestions are greatly appreciated. Overclocking all the parts of this build (CPU/GPU + Ram). I might, if you really recommend, be able to go around $700.
CPU/Mobo Combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.895118
$225 -$30 rebate
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
$47
GPU (Crossfire with the APU)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102988&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Video+Cards-_-Sapphire+Tech-_-14102988
$72 -$10 rebate + Dirt 3 Coupon (does that mean I get the actual game???)
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
$60 -$10 rebate
CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
$35
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
$47 -$10 rebate
DVD/CD Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
$30
SSD (don't need more space than this)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
$133
Wireless
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156306
$24
Wireless Mouse/Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201035
$20
Okay...I think that is it. If I forgot anything tell me. This is my first build. I've never even owned a Desktop Computer before.
Total:
$633 (including rebates + shipping)
G
Guest
Guest
No improvements??? Wow I must a really hit it good on this one. Do I need 8gb ram??? Or should I go with cas 7 1333 4gb ram??? Also does the DiRT 3 Coupon let me get the game (if it does I guess add that to the games list)???
With a Llano I would stick to the higher mhz RAM. 8GB is ideal for a modern system.
As far as the system, like I said, if its not a hard core gaming system, yes. I base this on what you said your usage was, if you're looking for a gaming system, like to run games other than simple flash games and java (like minecraft), then yea, some tweaking to the system would get you a better deal.
For example a Phenom II 965 CPU with a 6870 video card would be a better gaming grunt.
I have no clue what the Dirt 3 coupon is all about lol.
G
Guest
Guest
Yeah this will be only flash + java for now. Except if I get that DiRT 3 Game lol. So I guess this will work pretty good.
Just a random question. How far can I up the vcores when overclocking the CPU/GPU/Ram respectively with the hyper 212 evo.
Well, you say "for now", thats what makes me worry that you may be expecting more power needs later. You could make a couple changes and still stay in the same budget range and be ready for when that "for now" changes.
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
Thats going to perform better for gaming. As far as overclocking the llano,, no experience with it first hand, and haven't found too many online resources about going about it.
G
Guest
Guest
I will never get into gaming (as in buying disc games etc) only games that can be attained in other methods. I think I'll stick with the llanos as it is still a cheaper way to go with my needs.
Thanks for the help nekulturny!!!
No problem, good luck with it, that should give you a pretty decent system for what you're looking to do.
As far as overclocking the llanos.. like I said, I've had some trouble finding detailed information on em for overclocking. If someone does find em, I'd love to bookmark em *hint*
So far what I've gathered, getting the CPU to 3.8GHZ is a pretty solid bet, as far as overclocking the GPU portion of it, I'm still coming up empty.
