Hallo everyone
I've a pc with windows 7 64 bit, graphic card Sapphire HD 5850 and I've installed latest Amd Radeon driver. I've a Smasung LCD Monitor at 1680x1050 (DVI) and a Philips LCD Tv at 1920x1080 (hdmi) connected to the graphic card. I've set shortcut Alt+F1 to switch between this two monitor, the problem is that switching from Lcd Monitor to Lcd TV resolution don't change automatically from 1680x150 to 1929x1080. So i have to do this manually.
My pc is equipped with cpu Intel core i5 2500k and, using the integrated gpu with intel driver, i don't have the same problem switchig betwwen monitors...infa
tct resolution automatically adapt to the correct value.
Is there any trick to do the AMD driver doing the same?
Pietro
Pietro
