Solved
PSU, case, and fans for new build.
Last response: in Components
Hello! This is my first computer that I'm building. I would like a PSU, and a case with fans recommendation for $60 or so. I'm not sure how much space my parts will take up, but here they are:
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E168...
RAM http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Thanks so much in advance!
More about : psu case fans build
Best solution
For case: Fractal Design Core 1000 - Its M-ATX, perfect for your motherboard.($40)
you can get same spec cheaper hard drives like : http://www.newegg.com/Product/Product.aspx?Item=N82E168... - ($20 Cheaper)
For psu : http://www.newegg.com/Product/Product.aspx?Item=N82E168... - Antec is a respectable brand, 450w is the minimum wattage for your graphics card($35)
Case and psu add up to $75 and if buy that hitachi hard drive, the budget will be as expected ;)
DONT SKIMP ON POWER SUPPLY!!!
Thanks! :)
Ask the community
