Hi i'm finally starting my new build for gaming use and I have not done a build for a longtime and could use abit of dirrection with my selected kit. I.e better replacement for performance or budget. Currently i've got £1300 but can stretch that if need be.
CPU: intel i7 3770k, MB: Asus p8z77-v deluxe, GPU: 670 GTX (asus twin fan model), RAM: colsair 8GB dominator platinum c9 (x1/8gb), CASE: nzxt phantom tower.
Can anyone give good options for the PSU as I will be going sli with 2x 670 gtx's soon after and a suitable water cooling kit that will fit the case like the colsair h100 or respective models.
