No signal on monitor?
Recently I purchased a Radeon HD 7970 3GB video card, but when I hook my monitor up to it (Sceptre X246W-1080P LCD Monitor) I get "No Signal"
I use a DVI to DVI cable and have set my monitor to DVI, HDMI, and VGA, and they all yield the same No Signal result. When I hook my monitor up to the on-board video, it works fine. It also works fine with an older Radeon card.
Can anyone help me out?
5 answers Last reply
More about signal monitor
  1. What power supply do you have?
    Did you plug in both 8 pin power cables from the psu?
  2. Corsair CMPSU-1050HX
    And yes.
  3. Not sure why you would need a 1050w psu, as a 500w would be sufficient, but maybe it croaked?
    Have you tried different pci-e power cables?
  4. All of the components are new.
    Is there a way that I can check to see if my video card is recognized by my PC, even though the monitor is not hooked into it?
  5. I don't know what mobo you have but some basic things you could try is look in bios to see if you need to change it from onboard to PCI-E video adaptor.
    You could also try pulling the cmos battery for 5 minutes, then put it back in and see if that works.
Radeon DVI Monitors Graphics
