Mount Water Cooling System on Mobo
Last response: in CPUs
I havent installed one of these on the AM3 sockets, but just from the picture of the mobo you can tell that you need to remov the CPU HSF mounting screws - these are the ones that allow you to put the necessary back plate and front retaining mechanism in place.
there are decent enough instructions on the manufacturers website
Thank you for the fast reply guys. This is my first AMD build and I'm a little hesitant to pry the backplate off with a screw driver so what would be the best tool to use for removal?
Woah! The metal backplate on the motherboard should not come off. Any backplate which is part of your existing cooler will come away when you remove it...if it doesn't, it's integral to the motherboard.
The backplate for the Kuhler 620 will line up with the holes around the CPU socket, which will be the same ones used for the cooler you currently use. The backplate you have for the Kuhler 620 should fit on the motherboard with the existing metal backplate in place.
Ask the community
