Solved
Corsair CWCH70 Liquid Cooler work
IS Corsair CWCH70 Liquid Cooler working on motherboard LGA 2011 Socket ,and is it best for cpu cooling.
i m using i73930k processor with DX79 motherboard and cabinet is Cooler master CM 690 II plus (Mid Tower) 3 Fan.
4 answers Last reply Best Answer
More about corsair cwch70 liquid cooler work
  1. Best answer
    Corsair makes different models of the water cooling closed loop coolers and of the models that they make yours is third on the list with these two being better. They would get rid of more heat than the one that you have. If you have just one fan installed on the radiator then you can add a second fan to give better cooling power and you would have one fan on each side of the radiator with one fan pushing the air into the radiator and the other one pulling the air (push/pull setup)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181016
    so is it support LGA2011 socket
  3. If you click on the links and look at the details tab you will see that both of those coolers will work in the 2011 socket.
  4. Best answer selected by vishalnagar.
CPUs Corsair Cooling Motherboards Product
