Which MOBO and CPU will fit with these parts?
alexflcl
5
Hello,
I need to choose a MOBO and CPU which best fits with the next components.
Ram memory - 2x 4gb DDR3 1866mhz Kingston CL9
Disk - 120gb ssd OCZ Agility 3
Graphic card - 6850 1gb gddr5 Shapphire.
These are the things I have, and now I want a MOBO and CPU, in a near future I want to put one more 6850 graphic card to make an SLI. I dont plan changing that build in 2/3 years,
I want to spend around 200/300$, is there any 2x PCIE x8 MOBO and "nice" CPU in that price?
Thanks in advance :).
Aditional information:
Approximate Purchase Date: Tomorrow
Budget Range: 200/300$
System Usage from Most to Least Important: Gaming
Parts Not Required: I just want MOBO and Keyboard
Preferred Website(s) for Parts: Im reatiler, I can get nice prices from suppliers.
Country: Spain
Parts Preferences: None, just the "best ones" for those parts
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution: 22'' 1080p + 24'' 1080p
Additional Comments: none.
alexflcl
5
What processor should I get?
Is necessary to get a 2x pcie 8x-8x to get a 100% performance with two 6850 or with a 16x - 4x will be fine?
Is there any way to get a 2x pcie 8-8 and a processor between 200-300€?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
ASUS P8Z77-V LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard PCI Express 3.0 x16: 2 (x16/0 or x8/x8)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
alexflcl
5
Yeah, I know it's quite better, but that build is 450$ and I can't spend that too much. Asrock 990fx extreme3 and Amd FX-8180 is 290$.
I have no money, i'm broke :S.
alexflcl
5
Well, Finally I think i will get the FX 8120, asrock 990fx extreme3, 2x4gb ddr3 1866mhz kingston and 2 amd 6850 gddr5, with a 750W tacens radix V PSU.
