I want to know if this Build has a compatibily errors or problems. or any other stuff of some problem you find example the PSU or etc...
High Current Gamer Series 520W ATX Power Supply
http://www.microcenter.com/single_product_results.phtml?product_id=0348766
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
ASRock H77 Pro4-M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard W/ Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.910311&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=czg1j9gw6tzk
Seagate 500GB Pipeline HD SATA 3Gb s Internal Hard Drive
http://www.macconnection.com/IPA/Shop/Product/Detail.htm?sku=9688294&SourceID=k275760&cm_mmc=GAN-_-PC%20Part%20Picker-_-Primary-_-k275760&clickid=0004bf6280fbd8070ae04e024b854baf
Zalman Z9 Plus ATX Mid Tower Case Black
http://us.ncix.com/products/?sku=57910&vpn=Z9%20Plus&manufacture=ZALMAN%20TECH&promoid=1018
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-CD/DVD%20ROM%20Drives-_-Sony%20Optiarc%20America%20Inc-_-27118031&AID=10440897&PID=3938566&SID=
EVGA GeForce GTX 550 Ti 2048 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 02G-P3-1559-KR
http://www.amazon.com/dp/B004XUCCS6/?tag=pcpapi-20
Thank you for all the people that help me build this. i am almost done to buy it. just need this last check up from one of the pro's from this forum <3
