Hello all, first time poster (frequent reader). I'm moving to a new home which was recently renovated, and the contractor ran Cat5e cable to all the important rooms (bedrooms, family room, etc.) from the basement/garage where the cable/phone service comes in, which means (correct me if I'm wrong...) all I need to do is re-do the jacks from phone jacks to ethernet jacks at the room ends for an instant home ethernet network since I don't actually need phone lines...
I have some questions though. Here's an outline of what I have in mind (roughly):
The red lines signify wall jacks in each room where the wire run from the basement terminates. The modem is a motorola surfboard (I have cable internet). We have VOIP phone service from the cable company, so the phone base station will connect directly to the modem. There's home run coax running to every room along with the cat5e, so that'll go into the modem (and cable box in each room). The wireless router will be located in a central room that should cover most of the house (most likely an ASUS Black Diamond RT-N56U). The "TV" connection is for the new internet enabled TVs that can stream netflix pandora, etc. and have an ethernet port in the rear.
Questions:
1. What equipment do I put at A, B, and C for the best performance? My initial hunch based on research is Switch (8 or 12 port for expandibility when we expand the house), Router (doubles as a switch for that room), Switch (4 port should be enough for any room). The wireless router will serve as a switch for that location if needed. Is that correct?
2. The router installed as Equipment B will also serve as a hardware firewall to any device accessing the internet via the wired network, right?
3. Any suggested hardware for my purposes?
4. Equipment C will be replicated in rooms 4 and 5 if needed (i.e. multiple devices)
5. I should be able to plug a network capable printer with an ethernet port into a switch/router at any location in the house and be able to access it from any computer (either via a switch/router in another room or by wi-fi)?
Thanks!
Questions:
Thanks!
