This is my first time building a PC, so I thought it best to just use someone else's parts list.
http://www.pcworld.com/article/238006/build_a_gaming_pc_for_under_1000.html
This would suit my needs, I thought... I chose a few parts that were cheaper than this, but knew that I wanted to keep the most important components the same in case something went wrong.
The problem is, the mobo says "if the 4-pin ATX 12V connector isn't plugged in, the computer will not start", and the power supply doesn't seem to HAVE a 4-pin connector.
These are what I ordered:
Power Supply: http://www.amazon.com/gp/product/B004W2T2UQ
Motherboard: http://www.amazon.com/gp/product/B004ZBHMN8
Am I missing something, or are these two parts just not compatible?
And if they aren't, then what's the next step? Buy a different power supply? And if so, which one?
