What power supply do i need for intel (r) pentium(r)
I ned a new power supply for my old pc. I don't know witch one will work with this old pc?? Please help?
3 answers Last reply
More about what power supply intel pentium
  1. What are your system specs including grahics card.
  2. You do need to give us the components that you have in the computer and what the case size is , also what do you have for a psu now? If you have a midtower and the standard ATX style form factor then a good 500w should work.
    CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
    $59.99 and a $10 rebate makes the final price $49.99.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    If you want a good psu and don't mind spending $50 then you can consider this one.
    COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W ATX12V v2.3 Power Supply
    $39.99 and a $10 rebate makes the final price $29.99.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817171031
    Diablotek DA Series PSDA500 500W ATX Power Supply
    $23.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008
    Then you have the real inexpensive psu's that are less money and from lower quality brands and it will depend on what you want to spend.
  3. Review on the CM Extreme Power Plus 500W: http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-500-W-Power-Supply-Review/728 Although it can actually deliver its rated wattage, it can't do so efficiently and goes out of ATX specs over 80% load. The EP+ series from CM is plaqued with a well-deserved reputation for having liar-labels and then costing too much for what you actually get.
    Stay away from Diablotek! Diablotek is notorius for low-quality, high failure rate PSUs that take other components with them when they die. They're cheap for a reason.
    If you're looking for a good, inexpensive PSU, then get the Corsair CX430: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&Tpk=cx430 $35 after MIR. Those rebates are commonly $20 if you're willing to wait a few weeks for the next rebate. Without knowing what your system is it's hard to tell whether or not any recommendation is sufficient for your PC, but the CX430 shhould handle any PC with a graphics card up to an HD6850 level power draw.
Power Supplies Pentium Intel Components Product
