I have two XFX 6870s setup in crossfire. My new 600watt OCZ power supply is "SLI Certified" but nothing on it points to Crossfire.
The 6870's require 2x6pin PCI-E plugs a piece...and the power supply only had 2. So I bought 2 Molex to 6pin PCI-E adapters.
Everything appears to run just fine with issues. Any way for me to check power to make sure its right etc? I have very low knowledge on power supplies because its never been an issue before. I am only running one HDD and one SSD - Fans are a plenty to ensure I can move air in this case- I will have about 5 case fans, and my Cooler master heatsink has 2x120mm fans as well.
Tested out Bf3, Starcraft3, unreal 3, no issues.
Thoughts?
Thoughts?
