Will my build work
7 answers Last reply
More about will build work
  1. Don't listen to the above.
    AGREE
  3. if your buying it soon, at least get the supeior version of the 560 ti while supplies last. also i dont understand why the 2 above dont like the 7850, it performs better than the 3xx cuda 560ti
    edit: when i say soon for the gpu, it ends in 2 hours and 36 minutes on this edit
  4. I see now. I mistook his advice for something else lol.
    Thanks for understanding
  6. ok i will get the hd radeon 7850 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161406 this is the one im getting and do any of you guys know if it will fit the motherboard and if the board with all components can fit in the case i linked.
Build Systems
