Solved
Hyper 212 EVO? Corsair H100? or H80? HELP
  • CPUs
  • Cooling
  • Corsair
  • Evo
Last response: in CPUs
August 24, 2012 8:58:08 AM
HEY EVERYONE!
I have asked questions on this forum and received very intelligent answers. THANKS!
OK i have a Hyper 212 EVO CPU cooler and i am looking to upgrade preferably to a water cooler such as an H80 but would it be worth it?
My rig:
corsair Obsidian 650D <-- H80 will definitely fit in this case
LGA 1155 i7 2700K 4.1 Ghz
Gigabyte G1.Sniper m3
Gigabyte GTX 670 OC <-- worried if H80 will fit with this graphics card below it
800W 80Gold PSU
I plan on positioning the cooler where the 120mm outtake fan is on the rear of the case Corsair says to place it as an Intake but reviews disagree. Also would an H100 be a better choice to mount it at the top of the case where the 200mm outtake fan is?
Or should i just keep my Hyper 212 EVO?
Thanks in advance :D
More about : hyper 212 evo corsair h100 h80
a c 110 à CPUs
August 24, 2012 9:02:36 AM
What are your current temps?
m
l
August 24, 2012 9:13:45 AM
around 32c with nothing running at desktop and at 100% load all cores are around 57 - 60c
m
l
Best solution
a c 110 à CPUs
August 24, 2012 9:23:57 AM
Well those temps aren't that bad, especially for a overclocked CPU on a air cooler.
According to some people the H-80 is noisy, it will cool down your CPU around 5-8c under load.
If you have space you could get this- http://www.amazon.co.uk/Noctua-NH-D14-Processor-cooler-...
August 24, 2012 9:32:35 AM
Thanks for your help i guess i'll just go with the H100 as i would like to overclock a little more :D  maybe 4.5GHz thanks
m
l
a c 110 à CPUs
August 24, 2012 9:33:36 AM
No problem.
m
l
