Sapphire Radeon HD 5770 Eyefinity help
After months of saving, I have finally purchased a 2 other monitors to complete my collection. My specs are as follows:
Intel Core 2 Quad
6GB DDR2
Sapphire Radeon HD 5770 w/ 2 DVI's, HDMI and a DisplayPort.
I now have 2 Samsung 23" SyncMaster 2333SW's (both have a DVI and a VGA connection), and my main monitor is a HANNSPREE HF259H (Only has HDMI and D Sub which i find odd...).
I have both of the samsungs running on DVI and i planned to have the HANNSPREE run off of a displayport to dvi adapter because I just assumed the Hannspree would have a DVI, but it doesnt. So now that I already have this adapter, I thought Id just have the hannspree run off the HDMI port, and use the adapter to run DVI for the other samsungs.
All 3 monitors support 1920x1080, full HD. however, the D Sub on the hannspree wouldnt register a signal with a DVI to VGA, no matter my settings. and I know this monitor works at full HD because it played flawlessly with my PS3. But when I switch from PS3 -> Hannspree to PC -> Hannspree, the display shrinks by about an inch on top and bottom of the screen.
So my question is:
Monitor issue? Driver issue? Recommended solution? I can run eyefinity without fail between my samsungs+dvi's alone, but the current hannspree setup is a fail.
3 answers Last reply
More about sapphire radeon 5770 eyefinity help
  1. I'm a tad confused. If your Radeon has two DVI's and a HDMI with the two Samsungs running on the DVI, why not put the Hannspree on the HDMI?
  2. i tried that :/ the display comes out shrunk from the sides of the screen, no matter my settings. maybe ill post some pictures...
    and in order to use Eyefinity, i have to utilize the Displayport for atleast one of the displays.
  3. http://www.amazon.com/Display-Port-Male-Female-Adapter/dp/B002C97CAI/ref=sr_1_12?s=electronics&ie=UTF8&qid=1330928381&sr=1-12
    http://www.newegg.com/Product/Product.aspx?Item=9SIA07R07D8128
    All I can say then is to buy one of those.
    I've done DVI to VGA many times, I can't imagine why your monitor wouldn't pick up the signal other than a faulty port.
Radeon DVI Monitors HD Graphics Product
