Ghost Recon 2 Live Problem
andi
16
Archived from groups: alt.games.video.xbox (More info?)
Just got a copy of Ghost Recon 2. It won't let me sign onto live. Whenever I
try it says I need an update. So i try to downoad this update and a third of
the way through it freezes!!!!
Andi
G
Guest
Guest
Go to the dash board and erase the GR2 files (x-fer your save game to a
mem card). Put the game back in after a reboot and retry the the
update download. Sometimes it's not a freeze, just a moment where the
info pipeline gets clogged too. Hope it works!
Ace Frehley
andi
16
Thanks. I'll try that but think it might be the game now as it won't let me
save the game. When i go save the game it tells me its been saved and takes
me back to the pause menu but when I try to get off the pause menu and back
to the game it freezes like it does when the download fails, sounds like its
just ticking over doing nothing. So I turn it off turn it on again get to
the options screen try to load my saved game and each time now it says saved
game is dammaged
Hmmmmmmm
Andi
"Ace Frehley" <Ace.Frehley.1rr2jz@no-mx.Usenet-gateway> wrote in message
news:1120656395.4c76ee3e813155846a9b3caf55f98c37@teranews...
> Ace Frehley
G
Guest
Guest
> let me save the game. When i go save the game it tells me its been
> saved and takes me back to the pause menu but when I try to get off
> the pause menu and back to the game it freezes like it does when the
> download fails, sounds like its just ticking over doing nothing. So I
> turn it off turn it on again get to the options screen try to load my
> saved game and each time now it says saved game is dammaged
> Hmmmmmmm
> Andi
> message news:1120656395.4c76ee3e813155846a9b3caf55f98c37@teranews...
>> to a mem card). Put the game back in after a reboot and retry the
>> the update download. Sometimes it's not a freeze, just a moment
>> where the info pipeline gets clogged too. Hope it works!
>> Ace Frehley
You Live connection (your broadband connection, actually) might be the
problem. I've had to do Live updates on my broadband connection on
various titles for friends on a local "second-tier" cable ISP that get
the same type of file corruption when updating from Live. Their cable
company is aware of the problems and say they are trying to fix the
connection issues.
Like Ace wrote, the corrupton might well be from Live congestion, but
your connection might also be the cause.
Q
andi
16
Think it might be the connection now. The game kept freezing all the time so
I couldn't even play the single player campain. I took out the cable
connecting my xbox to the modem and then turned on the xbox. Started playing
the game and got 3 levels in with no problems and saved several times with
no problems.
Even if I don't try to sign in just having the cables connected effects the
game as it automatically tries to sign in when the game starts. Thus making
me think live is the problem. I'm with blueyonder so yo uthink this might be
the problem? I have played this game on live before as I bought it when it
first came out but then sold it a few weeks later. I bought this one 2 days
ago and I can't even get onto Live as I need the update to get on. What
should I do?
Cheers for your help
Andi
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news:KNSdnbRmV5HTe1bfRVn-gg@comcast.com...
>> Hmmmmmmm
>> Andi
>>> Ace Frehley
> various titles for friends on a local "second-tier" cable ISP that get the
> same type of file corruption when updating from Live. Their cable company
> is aware of the problems and say they are trying to fix the connection
> issues.
> Like Ace wrote, the corrupton might well be from Live congestion, but your
> Q
