CPU fan speed low when on high temps
Last response: in CPUs
- SolvedTurning up fan speed vs leaving them low and having higher temps - which is better for my GPU? Forum
- SolvedMy CPU temps and fan RPM are always high, but it's ice cold inside my case. Forum
- Blinking screen and gpu overheat (asus gtx 780 ti matrix) , ram frequency low , corsair h 110 fan start up speed is too high Forum
- Fan speed high then low Forum
- SolvediF i PUT THE CPU FAN AT HIGH SPEED, COULD BE GET SPOILED? Forum
- SolvedCPU fan speed and temps. Forum
- High cpu temp and fan speeds Forum
- Wrong CPU temps(speed fan) Forum
- SolvedCPU OPT Fan Speed Low Forum
- CPU heatsink fan speed low. Forum
- SolvedLow CPU Fan Speed Forum
- Low GPU fan speed leads to lower framerates and lower temps? Forum
- CPU fan super high RPM at boot, then slows down to normal speed. Forum
- SolvedCPU cooler fan speed for high end gaming Forum
- SolvedLow Speed CPU Fan Forum
- SolvedCPU Fan Speed 1900 and CPU Temp 50c Just from bios! Help! Forum
- SolvedHigh cpu temps. Need CPU fan/heatsink replacement Forum
- Speed Fan Temps!? Just added new heatsink + paste, now high temps!? Forum
- SolvedWindows does not start; cpu fan running at high speed Forum
- Solvedoverclocked CPU, RAM speeds dropped and high idle temps Forum
- More resources
