Im trying to build a decent computer rig for a cheap price. Surprised?? This is my first build and am looking to spend 600 and i have to buy Windows.
Will this run starcraft 2, diablo 3, skyrim on medium to high settings? also i only own a 1080p tv. Let me know your opinions. Thanks
Case: COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case - 34.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
PSU - COOLMAX CXI-600B 600W ATX12V ATX 12V v2.2 SLI Certified / CrossFire Ready - 54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159055
CPU - Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core - 124.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077
MoBo - BIOSTAR H61MGC LGA 1155 Intel H61 Micro ATX Intel Motherboard - 49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138332
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 - 39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
GPU - XFX HD-677X-ZNLC Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 - 109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150540
HDD - Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s - 79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
