System:
i7 3930k
Windows 7 Home Premium
GTX 680
Asus Sabertooth X79 board
Monitor: vw246h
Alright I can't identify exactly where the problem is coming from, so I will start with identifying the symptoms..
Fresh build here.. everything seemed to be going smoothly.. however my monitor is only recognizing 1024x728 as a resolution, cannot change it to anything higher..
During boot, when there once was the Sabertooth logo that flashed on the screen during post.. that is no longer there, the system just goes straight to the windows logo. Those familiar with the Sabertooth, while (Del) normally takes me to the bios program, that no longer works, and while I can still get in by hitting F8 and then selecting Setup.. the bios does not fit in the screen but rather looks like this..
http://s655.photobucket.com/albums/uu276/TGrizz/?action=view¤t=IMAG0269.jpg
(photobucket link)
Now what I have tried..
-Of course all windows updates
-intel driver updates
-gpu driver updates
-flashing most recent bios update
-fiddled with any setting I can find both in windows display options as well as nvidia control panel..
-for the bios post issues.. yes all the settings are turned on as far as display logo and what not.. havent changed anything there..
Just cant figure it out.. in stumbling around the net someone suggested (for someone elses post) that it was an intel driver issue.. but I have tried updating anything i could and it is all coming back up to date.. Not sure where to start..
Anyone?
i7 3930k
GTX 680
Monitor: vw246h
(photobucket link)
-gpu driver updates
Anyone?
