I am new to this site and am building my first computer in the next couple weeks. Had to keep it under 800 and I have to buy Windows. Just wondering if this build is good or a dud? Let me know what you think. Thanks!!
Case: Rosewill CHALLENGER Black Gaming ATX Mid TowerHDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
PSU: Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / EPS12V 80 PLUS BRONZE
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
MoBo: ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
GPU: SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
HDD: Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
Drive: LITE-ON DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
