This is my first attempt at a server build and I welcome any and all advice.
This is going to be a home server for file sharing, media streaming, personal web hosting,...
I have lots of parts cannibalized out of multiple old systems and I would like to come up with the most efficient system I can without having to spend much on new parts.
Here is what I'm working with:
3 Intel D945gtp motherboards with Pentium 4 3.4 ghz processors
http://downloadmirror.intel.com/15171/eng/D945GTP_TechProdSpec.pdf
3 3ware 9550sx 4 port raid controllers
http://www.newegg.com/Product/Product.aspx?Item=N82E16816116031
3 3ware 9000s 8 port raid controllers
http://www.3ware.com/products/pdf/9000_DS_012605.pdf
2 kingston 1GB ddr 400 sticks
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134136
2 kingston 1GB ddr2 800 sticks
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134487
A boat load of 512MB PC2 sticks
http://www.pc2buy.com/5395/patriot-memory-patriot-signature-512mb.html
14 500GB WD HDs WD5000YS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136032 (But not the bare drive type)
I'm also looking at this case to throw it all in
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352017
My plan was to use 1 of the mother boards, do 2 of the drives in a raid1 for the OS, and then use 2 of the 9000s controllers to setup 2 raid5 arrays with the other 12 HDs. Then I happened into the 9550sx controllers and I'm told they are a world faster then the 9000s so I would kind of like to use them. The problem there is that I don't have 3 PCI-X slots on those old motherboards and I would need all 3 of them to utilize all of the HDs I have?
So is there a an older (cheap) motherboard I could pickup with 3+ PCI-X slots so I could use the 9550sx controllers or should I just stick with what I have and use the 9000s?
Any other suggestions are also welcomed.
Thanks
Thanks
