I had to guess a little on some things such as type/speed of RAM and HDD RPM, but from what I've just found is a wattage of 435. I also added a bit of lenience there with 2 USB devices and 2 PCI-E devices in case you ever wanted to add any thing.
So you either want to go for 450Watts or 500Watts, with a PSU it's always best to go for a little more than needed because then at least everything will be powered fine and theres always a space for upgrades in the future. And of course PSU's usually deliver slightly under their max load.
You also need 2 PCI-E power slots for the GPU.
500 Watts would need a quality PSU, I'd advise getting a 600Watt PSU for those components.
Here's a 550Watt PSU by Seasonic...
