Hi Tomshardware
I have just finished assembling my first computer. But when i try to boot it the following happens:
Case light turns on, then turns off after a second
A second later, it turns on again, but nothing shows up at the monitor. It doesnt even indicate that it is connected to the pc. Everything inside the pc seems like its on, though. Though i didn't install an optical drive yet (as i lack the cables), the mobo should show the bios anyway, shouldn't it?
I have no idea what is causing this, and i would very much like your help
