New Power Supply / Graphics Card
  • Nvidia
  • Power Supplies
  • Graphics Cards
  • Graphics
March 6, 2012 5:53:34 PM
Hello, Im having some trouble installing my new graphics card and power supply. My old default power supply is 300w, im upgrading to a corsair 600w. Graphics are nvidia geforce 9100, upgrading to a Gtx 550ti. So the problem im having is that the new power supply doesnt have pins to connect to the old onboard graphics card so i cannot install my new graphics card. the 550ti requires 400w so i cant install it on my old psu. any help. When i turn my rig on lights and fans turn on but the monitor cannot detect a video source.
More about : power supply graphics card
a b ) Power supply
a b U Graphics card
March 6, 2012 7:30:49 PM
your power supply doesnt connect to the onboard graphics as such--you can even connect a graphics card to a
motherboard with no onboard graphics
to install the new graphics card just put it in the correct slot--make sure any 6 pin connectors are plugged into
the graphics card and 4 pin or 8 pin 12v is plugged into motherboard and 20/24 pin is plugged into
motherboard and turn on pc--if theres no display you are doing something wrong
m
l
