Want to control net speed through router for another lan wired router
How can I control the speed of my internet for another router connected to my main router via lan wired. I want to give limited speed. Is it possible
2 answers Last reply
More about want control speed router wired router
  1. Set the second router with a static address and then set bandwidth limitations on that IP or routers MAC on the primary router.
  2. that applies only if your routers are managable. For unmanaged routers the best you can do is drop their connectivity say from gigabit to 100m or from 100 to 10...
Routers LAN Internet Components
