I run a ECS C19-A 2.0 and a D 805@3.2 and cannot get the cpu voltage above 1.3 need to get to 1.37. The power supply is 500watts and the 12 volt rail is at 11.79, in range.
(for example, my 90nm X2 4200 is rated for 1.35V at 2.2 GHz.)
MU_Engineer is correct.
Taken straight off the AMD site:
AMD Athlon™ 64 X2 Dual-Core
Model 4200+
Ordering P/N (Tray) ADA4200DAA5BV
Ordering P/N (PIB) ADA4200BVBOX
Operating Mode 32/64
Stepping E4
Frequency 2200Mhz
HT Speed 2000
Voltage 1.30V1.35V
Unless you tell me the exact revision of your chip I couldn’t say. Use CPU-Z and post the details here.Does it mean I've dot a problem with my board's sensors or someting worse(the voltages are right)?
IT's an Asur A8V-MX, you don't have the option to play with the voltages. :? :? :?
What program are you using to monitor the voltage? Do any other voltages look off? Some motherboards do add extra VCore automatically, but not usually that much!Venice E6. IT makes 38° full load, can't be 0.15V above rated!!!
If your system is stable and the CPU temps are OK then I doubt it’s actually a problem. I would still do some research to see if this is typical for your motherboard and possibly contact tech support for the manufacturer.I use CPUZ and the voltage oscillates from 1.464 to 1.502 (but mainly 1.480).
Even in the bios, the voltage is the same. Does it mean trouble????
