Archived from groups: alt.games.video.xbox (More info?)
Recently purchased the HD pack, against the advice of many. Most
complaints concerning the HD pack are over it's picture quality. This
problem is quite different. I can get DVDs to play, and the Xbox's
dashboard loads and the Xbox (logo) load screen as well (when the tray
is closed), but immediately after that, the screen goes blue. This is
an HDTV, and everything is hooked up properly, obviously. (otherwise
the DVDs wouldn't play) Any idea what the problem could be?
On 12 Jul 2005 15:49:52 -0700, "aether" <vercingetorix@hotmail.com>
Gave us:
Change the output mode in the video menu to one that your TV
accepts.
> Gave us:
> accepts.
Appreciate the response. I've tried every output mode, including
setting all on 'yes', and each one 'yes' by itself, and nothing has
worked. I do get sound, however. Placing the cables in the regular
component input works, but not in either of the HD / digital ones. The
TV manual states that it supports both 480p and 1080i.
aether wrote:
>> Gave us:
>>> This problem is quite different. I can get DVDs to play, and the
>>> Xbox's dashboard loads and the Xbox (logo) load screen as well
>>> (when the tray is closed), but immediately after that, the screen
>>> goes blue. This is an HDTV, and everything is hooked up properly,
>>> obviously. (otherwise the DVDs wouldn't play) Any idea what the
>>> problem could be?
>> accepts.
....but not DIGITAL. You'll (possibly) have to wait for the 360 for DVI
video. The current Xbox is analog video only.
Q
Update -
Got it to work. I tried everything except disabling 720p whilst
enabling both 1080i and 480p. There's another problem, though. Despite
having a 'widescreen' television, I like the picture on 4:3 ratio; when
in the 480p setting (as opposed to regular component), however, it
remains on full screen, and I mean full screen. The picture isn't
nearly as crisp, and I can't get it back to 4:3 without going back to
regular component. Curiously, the Xbox dashboard (widescreen,
letterbox, normal) has no effect on screen size now that it's 'HDTV'.
(480p)
"aether" wrote in message ...
> Update -
> (480p)
How the screen is filled (4:3 vs 16:9) is a function of the HDTV, not the
XBox. The 4:3 and 16:9 modes on the XBox are simply to just match the
textures for whatever your HDTV is set at. Your HDTV should have a button
on the remote that allows it to easly be switched from 4:3, 16:9, 16:9 Zoom,
Superzoom, etc. Usually best results are when both the HDTV and XBox are
set the same, but some games take a little of experimentation.
Yep, the 4:3 oddity is normal. The first "Splinter Cell" is a good example
of this. This is a 4:3 game that looks beautiful at 4:3, but takes a major
hit when stretched out to 16:9. 16:9 Zoom was a halfway decent compromise
though. All the games that attempt "photorealism" suffer this in one way or
another.
"Forza Motorsports" is a good example too. It looks great on a SDTV, but
breaks down on an HDTV (any mode). The XBox simply doesn't have the raw
power to drive HD resolutions and remain "photoreal". If the new consoles
weren't just right around the corner, I would actually be considering
getting an 16:9 EDTV (480i/p only) for the consoles and only using my HDTV
for cable/movies.
BTW: You probably are already aware, but if not -- you can set the dashboard
to display at 480p instead of 480i by simply holding the L and R triggers
while simultaneously pressing the L and R analog stick "buttons". The
dashboard will reboot at 480p each powerup until you either do the above
again or remove the HD pack. Dashboard is much easier on the eyes at 480p.
Cheers,
-Eric
> > Update -
> > (480p)
Yeah, the remote works fine adjusting the ratio with everything else.
(component, composite, digital cable) When the Xbox is on, though, and
in 480p, the remote option to change the screen size is disabled for
some reason. It's as if it's locked in and it's not possible to change.
Perhaps it's a limitation with the TV.
> another.
Don't get me wrong, I can tell the difference between regular component
and 480p, but the ratio is ridiculous. It's the entire screen. Try
close quarters combat in Halo 2 with 10% of the screen missing and
enemies the size of real people!
> for cable/movies.
> Cheers,
> -Eric
Actually, I didn't know that. I tried it and it worked. Much
appreciated, Eric!
Now, if I can only get this screen smaller..
Keep in mind that some 480p games do display in 16:9 and should fill your
entire display with a widescreen set. You should be able to alter the
display either way though. Only a 720p or higher mode will lock to 16:9.
You can see which games support what at www.hdtvarcade.com You might also
want to post your problem over there for some more help.
"aether" <vercingetorix@hotmail.com> wrote in message
news:1121229948.826784.210050@g43g2000cwa.googlegroups.com...
>> > Update -
>> > (480p)
>> button
>> Zoom,
>> example
>> major
>> compromise
>> or
>> another.
>> consoles
>> HDTV
>> for cable/movies.
>> dashboard
>> 480p.
>> Cheers,
>> -Eric
> appreciated, Eric!
On 12 Jul 2005 17:45:11 -0700, "aether" <vercingetorix@hotmail.com>
Gave us:
>> Gave us:
>> accepts.
Try switching the green and blue lines at the TV while the blue
screen is up. Or, actually.. Is the color correct when the DVD
plays? Also, what brand and model is the TV?
On Tue, 12 Jul 2005 19:17:26 -0600, "Quaoar" <quaoar@tenthplanet.net>
Gave us:
>aether wrote:
>>> Gave us:
>>>> problem could be?
>>> accepts.
Good answer. Yes, he MUST use the component video inputs as those
are the only ones supported by the first gen Xbox HDTV hookup.
On Wed, 13 Jul 2005 04:06:18 GMT, "Eric" <nospm@nospm.not> Gave us:
Nice little trick! Thanks!
> plays?
Yeah, the only problem is it's impossible for me to not play the damn
thing at full screen, at least with the two games I've checked so far.
(Halo 2 & Destroy All Humans) It seems stretched, and with Halo 2, it's
harder to play because things are too f'n big.
16:9.
also
want to post your problem over there for some more help.<<<
Nice link. I checked it out, and both the games that have refused to
change ratio are 16:9. The thing that gets me, is that not even the
remote works in altering the size of the screen. In fact, the option to
change the ratio on the TV when I to go to 'menu select' with the
remote isn't there. I don't get it.
Does anyone else think it might simply be a limitation of the TV
itself? That it must display on full screen when in HD resolution? I
mean, the remote locks up and won't / can't change the ratio /
resolution. If I could get it in a smaller resolution other than full
screen, it'd look tremendous.
On 13 Jul 2005 03:34:47 -0700, "aether" <vercingetorix@hotmail.com>
Gave us:
>> plays?
Perhaps your TV is auto-adjusting to 4:3. After getting it "up". Try
looking into your TV's setting/setup.
On 13 Jul 2005 13:02:59 -0700, "aether" <vercingetorix@hotmail.com>
Gave us:
That would mean that it isn't really an HDTV.
So nobody else has experienced similar problems with the Xbox's HD
pack, in terms of resolution / ratio?
"aether" wrote in
Hmm. If you set the XBox screen ratio to 4:3 (with 480p/1080i still enabled)
will the HDTV allow a 4:3 ratio? On my HDTV, if the HD source is 4:3 I can
either set the HDTV to 4:3, 16:9 Stretch, or 16:9 Zoom. If the HD source is
16:9, the HDTV allows either 16:9 or 16:9 Zoom. (It can't "downscale" a
native 16:9 HD source to 4:3.) This hold true whether the source is from
the cable box (HD) or the XBox (HD).
That does seem strange that the HDTV is forcing 16:9 even when the HD source
is 4:3. A lot of HD content (especially local HD channels) is still only
4:3 and I can't see a manufacturer having the idea that all HD is 16:9. (?)
I'm sure you probably already checked, but there aren't any disable/enable
options in the user menu that might be giving this strange behavior? There
may be options in the service menu as well. You'll have to google your
particular model for the service codes to get in. If you haven't messed
with service menus in the past, you'll want to get familiarity with them
before making changes. Most service menus don't have "restore to default
settings" functions which means that doing changes (and not keeping notes)
can have to potential to hose the TV. There is plenty of googable resource
information on the subject though.
Cheers,
-Eric
"TokaMundo" wrote in message
> On Wed, 13 Jul 2005 04:06:18 GMT, "Eric" Gave us:
dashboard
480p.
No problem. I figured this "trick" would've been in the little instruction
manual that comes with HDAV pack by now and would be wide known. (?) I
guess not. If I remember right, this "480p dashboard" feature came as part
of one the Live updates a while back.
Cheers,
-Eric
> dashboard
triggers
above
> 480p.
instruction
part
Along the same subject, another "feature" after that particular Live update
was the damn "floating dashboard menu" when using the HD pack -- which is
enabled by default. That annoyed me to no end (like being sea sick), but
after some experimentation discovered how to turn that nonsense off:
Simply press "Y" and then "X".
Cheers,
-Eric
news:1121329208.894230.226570@g47g2000cwa.googlegroups.com...
although I can't help directly, my widescreen TV has always behaved with the
HD pack, but you could check out www.avsforum.com. This is where I did my
research before buying my HDTV and although its not a gaming site
specifically, there are LOTS of incredibly knowledgable people in there that
may be able to help you out (im assuming your problem is a limitation with
your TV that you aren't aware of). Do a search for your TV model and you may
found that your question has already been answered (almost every single one
of mine were).
Good luck!, I know how shitty problems like this can be
Wurm
> Cheers,
> -Eric
There are settings you can access other than the 'menu/select' button
on the remote? As I type, digital cable is on and I'm able to access
the 'format' options. (4:3, zoom 14:9, 16:9, widescreen, super
widescreen, etc..) However, when I attempt to play the Xbox that
feature is gone, and it remains in widescreen mode. What's more, is
that I'm unable to watch DVD's with the Xbox when it's hooked up to the
HDTV inputs. They simply don't show. BTW, I checked that site but
couldn't find anything concerning this issue. Thanks, though.
There are 1232 identified and unidentified users. To see the list of identified users, Click here.
