Building a new computer help!
Hello,
I've just made it my quest to build myself my first gaming computer. I've looked over newegg and a fair number of other computer retailers and come up with my parts. I just need to hear opinions and tweaks that might help me!
Specs:
Mobo:
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
video :
nvidia GTX 560 TI
PSU:
700W coolermaster eXtreme power supply
Case:
COOLER MASTER HAF X RC-942-KKN1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
CPU & Cooler:
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W
http://www.coolermaster-usa.com/product.php?product_id=3050&product_name=GeminII S524
I have an optical drive and 1tb harddrive left over from an xps 8300 that i will use as well.
please be as harsh or constructive as need be i am teh newb at this stuff! :)
3 answers Last reply
More about building computer help
  1. For gaming this is unbalanced. Don't get an i7, get an i5 (same gaming performance). With the 100$+ you just saved, get a better graphics card, like a 7870, or 670. If you want to further save money, I'd get a cheaper z68 mobo and a i5-2500k, then get an even better graphics card. Basically, the difference in gaming between a 2500k and a 3770k is MAXIMUM 5%. Most of the time, not even 1%. Also, the 2500k overclocks better. With the money you just saved you could get a gpu that performs 50% better or even more.
    You do the math.
  2. You'll need memory.
    What resolution are you gaming at?
  3. I will be using x4 2gb DDR3 sticks with two monitors at 1900x1080.ANd with regards to that motherboard, don't I need enough power connectors for the case fans and the cpu fan? I really do appreciate the feedback.
Homebuilt Cooler Master Computer Systems Product
