I'm looking for a quality full-tower case that will last me about 3 years. After extensive online and in-person research, I've narrowed my choice for a new case to the TT Armor w/ 25cm side fan or CM Stacker (either 810 or 830). I've come to like these two because of their looks, build quality, practicality, position of front-side I/O ports, BTX upgrade-ability, and filtration quality. While I have a slight problem with the Armor's door fins, I've read that they are easy to remove (or I could just leave them open). I've also read some negative reviews about the 830's build quality that have resulted in recalls.
Does anyone have experience with these cases (preferably both), as I can't quite decide. The 25cm side fan for the Armor just came out, so it is a little limited in reviews at this point.
Thanks for any input or suggestions!
