G
Guest
Guest
Basically I am looking for a pc case (ATX) which has a bottom mounted power supply, good cable management and a special door. The special door is one which is not like the normal ones where you slide it on because it is a massive pain when it is standing up. One example of this is the corsair obsidian 80d ( i think) where it has the two latches you pull and it comes off.
Thanks for the help in advance.
