Help with build
Approximate Purchase Date: 4-6weeks
Budget Range: $500
System Usage from Most to Least Important: gaming, surfing the internet, watching movies
Parts Not Required: keyboard, mouse, monitor, speakers, OS, PSU Kentek 850w, mobo. drive, case, HDD
Preferred Website(s) for Parts: newegg.com
Country: US
Parts Preferences: AMD CPU
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: this will be for watching HD 3D bluray movies, surfing the internet and playing games like WoW, Battlefield 3, COD MW3, Diablo III etc
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case -- OWNED
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM SATA 12X Blu-ray Burner with Blu Ray 3D Feature IHBS112-04 - OEM -- OWNED
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106369
MSI 760GM-P21 (FX) AM3+ AMD 760G Micro ATX AMD Motherboard -- OWNED
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130638
11 answers Last reply
More about help build
  1. my suggestions then:
    Phenom II X4 965: $110
    HIS HD 7850: $240
    Corsair CX 430W PSU: $45
    8 GB DDR3-1333: $40
    Hitachi 500 GB HDD: $70
    total: $505
    HIS HD 7850: $240
    8 GB DDR3-1333: $40
    total: $505
    i have a psu and hardrive already. 850w and 1 160 ssd and 1tb hd
  3. in that case, go ahead and get an ASUS HD 7870 at $335
    new cost is $485
  4. thank you for the input but why the phenom II 960T. and im still thinking between the 7850 - 7870-and 7950
  5. price. 960T is good as well (its a hexcore with 2 cores turned off) there's about $100 difference between each class of cards; 7770: $130, 7850: $240, 7870: $340, 7950: $450, 7970: $550
  6. but its not 100% the other 2 cores can be unlocked and the FX 6100 is only about $6 more and i found a $7950 on newegg for $399
  7. no guarantee on the second unlock. 6100 is WORSE at gaming than the 965 or 960
    actually i saw the FX series does great in games if overclcked and the mobo i have doesn't support the 965.
    Budget Range: $500
    Country: US
    Overclocking: Maybe
    anymore suggestions
  10. if the mobo doesn't support the 965, it won't support the 960 either, go for the 6100 in the case.
  11. it does support the 960T. All 95watt cpus are supported
New Build Systems Product
