I've gotten some good advice here and other forums, and I think I've narrowed my selection down and would like some of you experts to looks over my selection and make sure everything here is compatible and appropriate.
Approximate Purchase Date: in the next couple weeks
Budget Range: around $1000
System Usage from Most to Least Important: Photo editing (currently using PS CS4, plan to upgrade to CS5 or CS6. Plan on LR4 as well), some light video editing (cutting home videos of the baby that is on the way, nothing too extreme), web, MS office, etc. No gaming at all.
Parts Not Required: Monitor, keyboard, mouse, optical drive
Preferred Website(s) for Parts: No preference, other than just sticking with reputable dealers
Country: USA
Parts Preferences: No preference. Parts I've picked are just from seeing what others suggest.
Overclocking: Most likely
SLI or Crossfire: No
Monitor Resolution: One at 1600x1200 and one at 1280x1024. Probably upgrade the smaller one at some point before the computer runs out of life.
Additional Comments: Plan on keeping the computer for 5 years or more. My current desktop is about 6 years old, and I'd like to get similar life out of the new one.
CPU: i7 3770k - $350 Or should I stick with i7-2600k and save some money? Is it worth the cost to go with Ivy Bridge?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
CPU Cooler: COOLER MASTER Hyper 212 Plus - $20 - will most likely overclock (Already purchased)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Motherboard: [strike]ASRock Z77 Extreme4 - 130[/strike] ASRock Z77 Pro4 - $100 with CPU combo deal
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157296
RAM: [strike]G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1600 - $76.50[/strike] G.SKILL Ares 16GB (2 x 8 GB) DDR3 1600 - $97.75 (Already purchased)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558
HDD: Seagate Barracuda 500GB - $72
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
SSD: Not right now. Maybe a future upgrade when prices come down. I'm not really all that worried about startup time or application loading. Maybe a small cache drive, but then again, I can keep the cost lower by skipping it for now.
GPU: EVGA GeForce GT 430 (Fermi) 1GB - $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130609
Case: Antec Gaming Series One - $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129181
Power Supply: PC Power and Cooling Silencer MK III 500W Modular 80PLUS Bronze - $48
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703035
OS: [strike]Windows 7 Home Premium SP1 64-bit - OEM - $100[/strike] Switching to Win 7 Pro for the 32GB RAM capability for future upgrades. - $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992
Total = $975.75
How does this build look? I've read about interference between RAM and CPU coolers, so I think that is one area I'd like some confirmation that this will fit together ok. Also, is 500W appropriate? I think it is based on Outervision extreme power supply calculator, but I'd like some of you're opinions as well.
Thanks.
Country: USA
Total = $975.75
Thanks.
