Help on new build
Last response: in Systems
I gonna need some advice on some hardware round up.
Decided part:
CPU: i7-3770k
Mobo: Asus P8Z77-V Deluxe
Case: Haf X
HDD: 2x WD Caviar Black 2TB
Ram: Gskill Sniper Black
SSD:
Corsair Force GT 120GB
or
Intel 520 120GB
GPU: (same price, same warranty in my local store)
Asus gtx 680
or
Gigabyte
http://www.gigabyte.com/products/product-page.aspx?pid=...
PSU:
Corsair 850 AX
or
SeaSonic X-850
And the classic round up:
Silver Arrow
or
nh-d14
More about : build
go with a 520 SSD or a muskin chronos deluxe 240gb. they are both ery reliable and the chronos uses top quality nand
go with the seasonic power supply and get the nh-d14 as it provides better ram clearance
i would also go with a gtx 670 as it is within 5-8% of a gtx 680 and is 100$ cheaper
the antec 1100 is also a great case
Ask the community
