Closed Solved
Would this pc fit and would it run on 480watt power suply?
Don't even bother with those 2 pieces of POS.
Save up for some better quality components!
That PSU can't even output 480W.
4 answers Last reply Best Answer
More about would 480watt power suply
  1. I plan to build a custom pc and want to know if it would fit together being everything compatibly.
    Here are the specs:
    LOGISYS Computer CS368RB Red & Black Steel ATX Mid Tower Computer Case 480W Power Supply:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811148062
    ASUS ENGT440/DI/1GD5 GeForce GT 440 (Fermi) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121426
    ASUS M5A78L-M LX PLUS AM3+ AMD 760G Micro ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795
    G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBRL
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310
    AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
    480watt power supply that comes with the case.
    320 GB HDD from my VERY OLD HP (old as in with amd athlon 64 3600+ 1.9GHZ dual core)
    2 DVD Writers/Readers from my VERY OLD HP
  2. i agree.buy a good case and a quality power supply separate,the psu is an important part of of your system,you may like to post this thread in the new system build section of this forum
  3. Best answer selected by KoolKid193.
  4. This topic has been closed by Mousemonkey
Power Supplies Power Components Product
