Solved
Transfer speed between 2 Gigabit Lan PC through Straight Cable
Hi, I have a desktop and a laptop computer. both equipped with Gigabit Lan port... I connect them with Straight cable by assigning both computers IP address. I havnt use any switch or router between computers.... The problem is that my transfer speed is about= ~10MB/s..... As far i know the transfer speed should be around 70-80MB/s (125MB/s for Gigabit Lan)..... i cant figure out the problem.......... plz let me know the solution.......
Thanks
5 answers Last reply Best Answer
More about transfer speed gigabit straight cable
  1. Best answer
    You need a crossover cable to directly connect two PC's.
    Why not just buy a cheap Gbit switch?
  2. Go to the properties on each NIC, then choose configure. Try setting each NIC to 1 Gbps full duplex. See if that helps.
  3. Best answer selected by wam9xx.
  4. finally use a crossover cable.... its working now with gigabit speed......Thanks 4 all replies
LAN LAN Computers Cable Networking
