Cutting led wire , disk error insert system diskj
i was swapping my psu with an older and more powerful psu , but it wasnt a sata so i plugged everything back in the original one, while the case was open i managed to cut some wires that were for the led lights , the comp still starts without the lights but gives me "disk failure , check cables , insert system disk and press enter". could it be the wires? im sure they're just for led lights.
5 answers Last reply
More about cutting wire disk error insert system diskj
  1. check u r hdd sata cable insert properly
  2. is your drive been seen in the BIOS? and re check all your connections.
  3. I would repair the cables I cut and retest.
    all the cables are plugged in as tight as possible and how would i check if its recgonizing the hdd, it shows which one to boot 1st including hdd, boot agent etc.. so is it being recgonized there?
  5. i have tried swapping the psu and changed the sata cables , and still get the error message, and doesnt seem to be recgonizing HDD in bios
Light LED Monitor Disk Error Components
