Are these parts compatible/good build?
Last response: in Systems
Hey everyone, can you tell me if this is a good build for gaming?
Approximate Purchase Date: (this week)
Budget Range: ($1,000-$1,300)
System Usage from Most to Least Important: (Gaming, homework)
Parts Not Required: ( keyboard, mouse, monitor, speakers, OS, Cd Drive, Cooling, RAM, Hard Drive
Preferred Website(s) for Parts: newegg.com
Country: USA
Parts Preferences: by brand or type: Intel processor,
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: NONE
Additional Comments: Please tell me if the parts are compatible with each other. Also is the motherboard listed a good overclocker?
AMD Radeon 7970 graphics card
Xion Predator Case
Intel i5 3570k Processor
CORSAIR CWCH60 Hydro Series
Gigabyte GA-Z77X-UD5H
850 Watts - Raidmax RX-850AE 80 Plus Gold Power Supply
RAM - 1600 CORSAIR. 8gb
These are the parts that I really need. All other part that is not listed above I already have.
Is this build any good? And suggestions to any changes? Thanks so much!
Homebuilt system Expert
You could save a bit by going with another motherboard:
A 850w psu? Do you really need Gold rated? That's major overkill. A good bronze rated 600w would be overkill. That's really an unbelievable price on a Gold 850w, but that's because RAidmax makes junk, actually they don't make them, some company called Andyson makes them.
A big clue that it's not very good is the warranty of 2yrs, any other Gold rated psu will have 5-7yrs warranty.
There's no good deals on PSU's right now though, so wait a few days, something good that I can recommend will come up.
Don't forget that I am planning to overclock, so that might take up a bit more power. I was also thinking of a brand called thermaltake, are they any good?
It's obvious your going to overclock.......already considered
A 600w psu would be more than enough.
Thermaltake is crap too. Stick with XFX, Corsair, Antec, OCZ (ZS or better), Seasonic, FSP.
Ask the community
