Greetings...
I have an HP Elite M904N PC running in a different case from the factory standard. It has an IPIBL-LA (Berkeley) motherboard with the core 2 quad q6600 chip from Intel. 4 gigs of ram, with a GeForce 9600 gt video card with 1gig of video ram. Everything running on a 650 watt power supply.
Recently I made the dumbest move ever, and spilled some fruit punch in the case, while the pc was turned on. It immediately shut off, without me doing anything and would not come back on. My first thought was the power supply fried itself, but I tested it and it works fine. Closer inspection revealed black burn marks in one of the 4 pin connector holes on the motherboard next to the core 2 quad chip, that a power cable plugs into. The 4 pin connector on the cable from the power supply also has burn marks in one of the 4 pin holes. I don't smell anything burnt per se, nor do I see anything weird on the core 2 quad chip. I have removed the video card, and unplugged power to everything but the motherboard and the quad core chip.
My best guess is I've fried either the chip or the motherboard, but I don't have another board to try the chip in to find out, or could both be fried? I did try an older motherboard in my case and it came on fine (thinking it might have friend my power switch).
Any help anyone could give would be most helpful. I can't afford to replace motherboard and chip both for some time, it's also well out of warranty, so I need help major.
Thanks!!!
Thanks!!!
