Solved
UV Light Help.
Is there a UV light kit other then the logisys one with all the wiring and pci slot on/off switch? i just want one with molex power....
3 answers Last reply Best Answer
More about light help
  1. Best answer
    At $20 each I don't really consider this affordable but it does fit the bill
    Lamptron Inverterless Cathode Spectral Bar - UV
    http://www.frozencpu.com/products/13050/lit-274/Lamptron_Inverterless_Cathode_Spectral_Bar_-_UV_A_World_First.html?tl=g6c451
    Might find it elsewhere cheaper, Enjoy
  2. Best answer selected by ThePlaneAddict.
  3. Thank you! Thats exactly what i wanted!
Power Supplies Light Switch PCI Components
