Hey guys! I recently bought a new PC, except for the graphics card that i bought in November.
I'm a bit worried because this is my third day using it and it already crashed 2 times.
The crash consists on a very high pitched sound, the mouse stops working, and the system just stops responding. It happened yesterday while playing Skyrim, and it happened today while loading 3ds Max 2012.
I installed almost all windows updates, AVG free antivirus and an application that came with the motherboard called EasyTune 6. I'm aware that this application is used for overclocking, but at the moment it isn't overclocking i think. Do you think i should uninstall this?
Here are my specs:
CPU Intel 1155 i5 2500k (3,30GHZ)
Corsair PC3-12800 1600MHZ 16GB DDR3
Gigabyte Z77-D3H
Seagate momentus XT 750GB (where I installed windows)
Asus HD6970 2GB
What do you guys think it may be?
[EDIT] So, the weirdest thing just happened (I don't know if it's related but may be relevant). I turned on the PC, but the power kept going down and up again, without doing that first beep sound or showing any kind of image... It only started after powering up and down for like 10 times.
Here are my specs:
Gigabyte Z77-D3H
Asus HD6970 2GB
