Closed Solved
Will these new PSU and graphics card work with my cpu?
I play World of Warcraft and need an upgrade in my graphics card and PSU i was just wondering if these that I have found will work with my current system specs.
System specs:
CPU 2.7GHz Intel Pentium Dual Core e5300 2 2.60 GHz, 2603 mhz, 2 CORES 2 LOGICAL PROCESSORS
Memory 4GB 800MHz DDR2
Graphics 256MB (shared) NVIDIA GeForce 7050 integrated graphics chip integrated graphics chip
Hard drives 750GB, 7,200 rpm
Optical drive dual-layer DVD burner
Networking 10/100 Ethernet LAN
Operating system Windows 7 Home Premium (64-bit)
POWER SUPPLY 250 W
here is the power supply: http://www.amazon.com/gp/product/B002RWJGHC/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=newdepmed-20&linkCode=as2&camp=1789&creative=9325&creativeASIN=B002RWJGHC
and here is the graphics card: http://www.amazon.com/gp/offer-listing/B003RH09AY/sr=/qid=/ref=olp_tab_used?ie=UTF8&colid=&coliid=&condition=used&me=&qid=&seller=&sr=
6 answers Last reply Best Answer
More about will graphics card work
  1. Yes it should work, what motherboard are you using? You should take a better PSU like this one: http://www.amazon.com/Corsair-Certified-Compatible-Platforms-CMPSU-600CXV2/dp/B004W2T2UQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1346454459&sr=1-1&keywords=corsair+power+supply
    it's more reliable than the thermaltake and better quality too.
    what is the screen resolution? And where are you from? Can you order from somewhere else than amazon?
    The video card is getting old and you might find something better depending on budget.
    my screen res is at 1366 X 768. i am from lower PA, USA. and yes I can order from somewhere else besides amazon.
    My computer is a eMachines ET1831-03.
    This psu you linked is great! I will look for a new graphics card although I am not sure the cutoff point for something that would be compatible with 600w psu. If I could get some recommendations for a nice graphics card that would be helpful as well :).
  3. Best answer
    you could put any GPU with that PSU as long as you don't use CF/SLI.
    You probably have a 1.0 PCIe so you shouldn't go with the latest Nvidia 600 or AMD 7000 unless you can find a BIOS update for your MB.
    You didn't specified a budget, you can look for something like aquahero said, a GTX 550TI should be plenty for all games because at that resolution the load will be place on the CPU. 1 advice I can give you is try to get a gddr5 video card.
  4. Best answer selected by aquahero.
  5. This topic has been closed by Mousemonkey
Power Supplies Graphics Cards World Of Warcraft Components
